Activity Forums Adobe After Effects Stabilizing Levels with Color Stabilizer?
  • Stabilizing Levels with Color Stabilizer?
    Posted by Bob Cole on February 26, 2006 at 4:55 am
    I can’t locate a thread or tutorial which I think I’ve seen on the COW, regarding stabilizing the levels in a time-lapse scene. In my case, it’s a scene from an extremely high-speed technical camera, where the high shutter speed and the HMI lights combined for exposure levels that are a bit “fluttery.”
    I believe the advice was to use Color Stabilizer. I need some kind of “automated” approach; there are too many scenes to use a manual approach with setting levels, and in any case, when I’ve tried the Levels route in the past I had zero success.
    I thought there was something in Boris CC that would help but I haven’t been able to find it.
    Any help would be greatly appreciated.
    — Bob C
    Bob Cole replied 20 years, 6 months ago 2 Members · 2 Replies
  • Pentti Kakkori
    February 26, 2006 at 9:39 am
    Red Giants FilmFix plugin. It’s quite expensive,1995 USD. You can download demo to test if it works with your material.
  • Bob Cole
    March 5, 2006 at 6:28 am
    Thanks. You’re right, it’s expensive.
    The problem I have with AE’s Color Stabilizer is that it only stabilizes a portion of the image at a time. I am thinking of running CS several times — what do you think of that approach?
    — Bob C
