Stabilizing footage from a 35mm scan
I have this scanned footage, 24p 2084×2084, now as a prores4444 file, a 16minute reel. The footage is rather shaky because of the scanning process, the whole picture oscillates up/down. Using the warp stabilizer in AE gave a good result when used on a 4 second clip from this footage, which was a single scene. As i’ve understood, the warp stabilizer will not work on multiple scenes in a sequence, similarly to tracking, which needs a single moving object to track, which is not possible when the scenes change. Another problem with warp stabilizing the whole 16 minutes is AE performance. The analyze process crashes AE when applied on bigger files. I have adjusted the cache size and allocated the cache folder to a drive with 1tb of free space, yet to no avail. It seems that the analyze process fills up RAM as well and results with “Application memory full” error, at which point the system is non-responsive. (I’m on OSX, ML)
Is there a way to batch process individual scenes with the warp stabilizer? Or is there a good solution for stabilizing such 35mm captured footage? There is definitely the manual process of assigning objects in each scene, yet as there are many more reels coming in, it would be good to use a more convenient method. e.g batch warp stabilizing scenes.
