Activity Forums Adobe After Effects Stabilizing a panned shot – getting frustrated :(
  • Stabilizing a panned shot – getting frustrated :(
    Posted by Julian Elliott on February 25, 2016 at 8:30 pm
    Hi there
    Last year I did a panned day to night time lapse. It looks really nice apart from it’s not quite stable.
    I’ve done the quick and dirty method of trying to use Warp Stabilizer but it looks horrid and so I was wondering if I would fair better with the tracker.
    So far I have nicely stabilized the lead-in of the footage before it pans but my problems begin when the camera starts panning across the scene.
    I was just adding a single point from the Tracker under stabilization but it froze the footage in one place.
    How do I stabilize the pan across using the tracker? Where am I going wrong?
    Any help is greatly appreciated as this one is making my head spin a lot 🙁
    Kevin Camp replied 10 years, 7 months ago 3 Members · 2 Replies
  • Kalleheikki Kannisto
    February 26, 2016 at 7:46 am
    You can add a manual pan to the stabilized footage. Enlarge the footage slightly. Add a null and parent the footage to it. Move and keyframe the null so that the first and the last frames are in place (in frame), then scrub through to see if you need additional keyframes to keep it in frame. You’ll probably need to adjust the motion in curves editor to make it smooth.
  • Kevin Camp
    February 26, 2016 at 8:46 pm
    you can also choose to just stabilize the y-axis, leaving the horizontal movement of the pan intact (unless you were also trying to smooth horizontal movement).
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
