Activity Forums Adobe After Effects Stabilizing a long take…
  • Stabilizing a long take…
    Posted by Mark Pfeffer on January 8, 2019 at 11:50 pm
    So, I have a continuous shot that was filmed at 6k.
    It was filmed on a steadicam rig. The op did very well for the move but there is still some human error involved. I’ve stabilized a thousand shots but none this long.
    Any ideas on how to properly stabilize a :50 second shot?
    Blaise Douros replied 7 years, 8 months ago 2 Members · 2 Replies
  • Mark Pfeffer
    January 9, 2019 at 5:40 pm
    Thanks for your response Dave. My question is more geared towards software and approach. I feel like Adobe’s stabilizers won’t handle a long shot well. The shot as well, is fairly dynamic.
    Wondering if Resolve’s solver would be best.
  • Blaise Douros
    January 9, 2019 at 8:23 pm
    If you’re talking about using Warp Stabilizer, just let it cook away, and start with a low number for your Smoothness setting–like, 5%. If that’s not enough, then you can crank it up a little. Make sure to use the Detailed Analysis under Advanced settings.
    If you’re talking about resolving a couple of minor shakes, you can use the old-fashioned point-track stabilizers, and keyframe in and out of stabilized sections; i.e. when everything is fine, return the comp to its normal position and size.
