Activity Forums Adobe After Effects Stabilized Precomp from Mocha without MochaImport?
  • Stabilized Precomp from Mocha without MochaImport?
    Posted by Bobby Yarsulik on January 10, 2014 at 2:36 pm
    Was just curious if this process is possible without the MamoWorld plugin MochaImport+.
    I use the plugin, but someone I know does not. Wanted to know if the same process can be used to make a precomp like the plugin does?
    I know that you can import the tracking data, just wasn’t sure if you could do the precomp.
    Roei Tzoref replied 7 years, 2 months ago 5 Members · 5 Replies
  • Roland R. kahlenberg
    January 12, 2014 at 4:54 am
    mochaImport+ does the heavy-lifting and adds productivity gain AFTER you have completed your tracking. Your friend doesn’t need the plugin if the tracking and mochaImport+ stuff is done on your machine.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Ross Shain
    January 13, 2014 at 10:45 pm
    Just to mention, you can also choose to “invert” your tracking data on export from mocha to stabilize.
    This is different than the useful mochaImport script that automates a stabilize/destabilize pre-comp workflow, but can help when needed.
    -Ross
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
  • Martin Dust
    September 30, 2015 at 11:58 pm
    I need to do “stabilized precomp” option without MochaImport because my trial time is expired.
    How can i do it with Mocha?
    I clicked export track data and invert but it’s not work…
    Stabilized working with “Power Pin CC”
    But normal mocha track is just exporting “Corner Pin”
    How can i export power pin my mocha data?
  • Ross Shain
    October 5, 2015 at 4:31 pm
    Theoretically, any user could create expressions that invert the 4 corner tracking data, pre-comp and than apply the inverse to it. But this is what Mamoworld does so well and it is an incredibly affordable tool: https://aescripts.com/mochaimport/
    Ross Shain
    Imagineer Systems
  • Roei Tzoref
    June 24, 2019 at 9:46 pm
    here’s how to do stabilized precomps with native tool in Ae CC 2019:
    https://vimeo.com/343994474
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
