Activity Forums Adobe After Effects Stabilize then unstabilize a clip
  • Stabilize then unstabilize a clip
    Posted by Filip Stillerska on January 19, 2019 at 2:23 pm
    I have stabilized a clip, applied different effects to it and now I want to unstabilize the clip again.
    Because of miscellaneous reasons, I stabilized the clip with the motion tracker, not the Warp Stabilizer VFX (I’ve had some serious issues with the Warp Stabilizer VFX lately, however, I’ve submitted a bug report to Adobe about this).
    Anyway, I know that in the new composition containing the pre-comp with the applied effects I’m supposed to pickwhip:
    • Position (in the new comp) to the Anchor Point (in the original comp)
    • Anchor Point (in the new comp) to the Position (in the original comp)
    • Rotation (in the new comp) to the Rotation (in the original comp) and multiply it by -1
    But… what about the scale? How do I “reverse” the scaling caused by the motion tracker when the stabilizing process took place?
    Filip Stillerska replied 7 years, 7 months ago 2 Members · 6 Replies
  • Kalleheikki Kannisto
    January 20, 2019 at 7:45 am
    I would try
    100/pick-whipped-scale
    Senior Graphic Designer
  • Filip Stillerska
    January 20, 2019 at 9:29 am
    Trust me Dave, it was absolutely necessary.
    The project is more complex than what it looks like from the screenshots.
  • Filip Stillerska
    January 20, 2019 at 9:30 am
    Unfortunately, that didn’t work:
    January 21, 2019 at 1:13 pm
    Scale is 2 or 3 dimensional array, so you would need to construct that differently.
    If 3-dimensional, it would be [100/pick-whipped-scale[0],100/pick-whipped-scale[1], 100/pick-whipped-scale[2]]
    If 2-dimensional, drop the third part.
    Don’t know if it will actually do what you want, but it might.
  • Filip Stillerska
    January 21, 2019 at 7:02 pm
    No, it just made the clip smaller, unfortunately. Hmmm, I thought this wouldn’t be THIS hard to figure out. Not a huge problem, though. I will just have to use the Warp Stabilizer VFX, even though that is not a problem-free experience either.
  • Filip Stillerska
    January 27, 2019 at 7:24 pm
    Finally figured it out thanks to Rick Gerard on the Adobe Community website:
    x = value[0];
    y = value[1];
    tx = comp(“20180915_203237”).layer(“20180915_203237.mp4”).transform.scale[0];
    ty = comp(“20180915_203237”).layer(“20180915_203237.mp4”).transform.scale[1];
    nx = x/tx*x;
    ny = y/ty*y;
    [nx, ny];
