Activity Forums VEGAS Pro Stabilize questions
  • Stabilize questions
    Posted by Paul Gregory on February 5, 2012 at 12:42 am
    I have a couple of questions about the Stabilize function that’s now found in Vegas.
    I would have thought that if I had ‘stabilized ‘ a clip that there would be some indicator on the clip itself rather than having to go to see the takes, rather like the color change on the pan/crop tool, once you have used it. Did I miss some setting or something?
    Is it possible to select several clip at once & have them all stabilized at once instead of having to select them one at a time? I seem to recall that you can do this in preview window only.
    Thanks in advance
    Paul Gregory replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
