Activity › Forums › Adobe After Effects › Stabilize ONLY rotation
  • Stabilize ONLY rotation
    Posted by Tomas Medek on March 4, 2018 at 7:05 pm
    Hello everybody ☺
    Is there a way how to stabilize rotation ONLY? I have a 5 min timelapse of the ship comming to the harbour. The camera was mounted on the ship so now the horizon is bouncing and the ship is steady. I would like to stabilize horizon and let the ship bounce.
    What ever I try (stabilize motion, warp stabilizer) I have no success. Ship was providing very complicated move and the trackpoints are comming out of the frame. But I do not want to stabilize all axis. I just want to keep horizon steady – rotation only.
    Anybody to help me? Thanks!
    Blaise Douros replied 8 years, 6 months ago 5 Members · 6 Replies
  • Mark Whitney
    March 4, 2018 at 10:47 pm
    It would require purchasing a very useful $50 plug-in but you might want to take a look at this:
    https://vimeo.com/121233653
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Cassius Marques
    March 5, 2018 at 5:09 pm
    Do you have any two points of the harbor that can be tracked? The default tracker can stabilize rotation…
    Cassius Marques
    http://www.zapfilmes.com
  • Blaise Douros
    March 6, 2018 at 6:40 pm
    You could do a full stabilizing pass with Position and Rotation, and then just delete the Position keyframes.
  • Steve Bentley
    March 7, 2018 at 8:44 am
    Horizons are great for pulling a rotation track off – even without any detail on the horizon.
    Pre comp your shot with two thin vertical masks on either side of the shot where you have a clean horizon. So there will be two strips of image that run vertically and the rest will be your background color. Then, in the outer comp track the change in color at the horizon as it slides up and down in these two mask slots. You will only get y values in your rotation track but it means that your x track isn’t sliding all over the place. Depending on the shot sometimes you have to use the same trick before you do the Y track (but with thin horizontal masks) and “stabilize” it left and right so your roll axis point doesn’t drift around.
  • Tomas Medek
    March 7, 2018 at 9:02 am
    “Do you have any two points of the harbor that can be tracked?”
    That is the problem. I don’t have two points that stays in the frame all the time.
  • Blaise Douros
    March 7, 2018 at 5:51 pm
    Ohh, this is a GREAT trick. I’m going to remember this one.
