Activity Forums Adobe After Effects Stabilize only horizontally?
  • Stabilize only horizontally?
    Posted by Chemix Ferreiro on July 3, 2008 at 4:31 pm
    Hi all
    I’m trying to stabilize a crane shot taken on a windy day = horizontal wobble. The up and down motion is perfect but start & end are horizontally moving. Is there a way to remove that unwanted horiz. wobble using the stabilizer in AEF?
    Thanks a lot in advance
    BUNKER studio
    “edit in paradise”
    Randy Mcwilson replied 18 years, 2 months ago 2 Members · 1 Reply
  • Randy Mcwilson
    July 3, 2008 at 11:50 pm
    This is very simple. Use the tracker,then select STABILIZE, and when you do the “apply” step, it will ask you X,Y, or both. Select X (horiz) only.
    If not familiar with tracker, there are tutorials all over about it.
    Eternity…don’t miss it for the world.
