Activity › Forums › Adobe After Effects › Stabilize on X or Y Axis using Mocha Data?
Posted by Jason Mckee on February 14, 2011 at 8:31 pmIs it possible to stabilize on only the X or Y axis using Mocha’s tracking data? thanks in advance.
-jmNathan Wood replied 14 years, 1 month ago 4 Members · 6 Replies -
Graham Macfarlane
February 15, 2011 at 12:34 pmNot sure about the context of your question but I would have thought it possible to stabilize fully in Mocha then bring the data back into AE onto a Null and then pick whip onto another layer/null only the X or Y stabilizing data that your interested in.
Graham Macfarlane
3D animator and VFX specialist
London UK -
Jason Mckee
February 15, 2011 at 6:10 pmHow I’ve always stabilized my footage using Mocha is to first track the footage in Mocha. I then take that tracking data into AE and apply it to the layer or a null that needs stabilized and then delete all of the keyframes (position, rotation and scale) except for the Anchor Point keyframes. If I applied it to a Null then I link the layer to the Null. This will stabilize the layer. However, there is no separate keyframes for the X or Y axis so how would I delete these? thanks.
-jm -
Bartek Skorupa
February 15, 2011 at 10:19 pmGo to the first frame of the stabilized piece, read the value, let’s say it is 365 for x and 290 for y.
Add an expression to the property and depending on which axis you want to keep, you should type in something like:x=value[0];
y=290;
[x,y]or:
x=365;
y=value[1];
[x,y]That’s, what I would do.
The expression will read the value, and leave one axis and set the other axis to the value you specify.Bartek Skorupa
Warszawa, Poland -
Graham Macfarlane
February 15, 2011 at 11:35 pmI don’t think you can delete an X key frame without Y being deleted, and vice-versa.
Lets say you want to use only the X data from your track.
If you pick whip the X field to another null, by default the expression should read something similar to:temp = thisComp.layer("Null 1").transform.position[0];
[temp, temp]The result will be that the new Null X and Y will equal the tracked X value.
Change the above expression to:temp = thisComp.layer("Null 1").transform.position[0];
[temp, X]Where X is a number of your choosing.
Graham Macfarlane
London UK
