Activity Forums Adobe After Effects Stabilize Footage In After Effects
  • Stabilize Footage In After Effects
    Posted by Ian Leo on January 3, 2011 at 1:09 am
    Hi. Does anyone know how to stabilize shaky footage in After Effects without motion tracking? Is there a plug-in that I can download or that comes with After Effects? I tried the motion tracking method and it worked, but I want to sort of turn the camera 360 degrees round and the point where I want to track might go out of sight. Thanks! 🙂
    Chris Wright replied 15 years, 8 months ago 3 Members · 2 Replies
  • Todd Kopriva
    January 3, 2011 at 7:16 am
    > … but I want to sort of turn the camera 360 degrees round and the point where I want to track might go out of sight.
    So use more than one track. I.e., track one element in the shot until it goes out of sight, and then use another one, and so on.
    I don’t think that you’re going to find a simpler way to stabilize motion in After Effects than using the Stabilize feature in the After Effects motion tracking system.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Chris Wright
    January 3, 2011 at 8:34 am
    just a quick tip, regular stabilization doesn’t work on pans, but if you’re keeping an object centralized, it should work. alt-drag the tracker to new trackable spots before they leave the border.
    for pans, you’ll need to use timewarp, syntheyes, deshaker(virtualdub)
    https://technicolorsoftware.hostzi.com/
