Activity Forums Adobe Premiere Pro Stabilising camera shake
  • Stabilising camera shake
    Posted by George Tav on September 25, 2015 at 12:04 pm
    Hello everyone.
    We have some footage that’s shot on a DSLR on a zoom lens without the stabiliser switched on the lens, so as you can imagine, the shake on the footage is pretty extreme.
    We have tried using the Warp Stabiliser in Premiere Pro and this has distorted the frame, which makes it unusable.
    We have also tried motion tracking in After Effects and even though the subject (a burger) isn’t shaking around in frame, the background seems to be shaking a lot, which is very noticeable in some of the corners in shot.
    So then we went to Mocha to try and track the motion but ended up again with the shacking corners.
    Can anyone suggest any other methods for stabilising a shot or does it sound like if these techniques didn’t work, then it’s un-savable?
    We only have the Adobe CC but if there’s any other software or plug-ins then we might purchase them if you advise this.
    Thank you for your time and help in advance.
    Looking forward to hearing from you soon.
    All the best
    George
    George Tav replied 10 years, 11 months ago 2 Members · 2 Replies
  • Curtis Cosby
    September 25, 2015 at 1:57 pm
    George,
    This may be something that you can try to help. Without see some of the footage it will be hard to know if this is what you mean by “this has distorted the frame, which makes it unusable.” but hopefully it will help.
    https://www.youtube.com/watch?v=KALsx-HDJjE
    Curtis Cosby
    Multimedia Assistant
  • George Tav
    September 29, 2015 at 2:54 pm
    Thank you very much for your reply Curtis.
    I have had a go with this method on the clips and it’s worked with most of them, which is better than where I was before.
    Thank you again.
    All the best
    George
