Activity › Forums › Adobe After Effects › Stabilise forward moving tracking shot
  • Stabilise forward moving tracking shot
    Posted by Phil Beastall on October 17, 2008 at 12:46 pm
    I know how to stabilise a static shot (or an attempted static hand held shot) but if the camera is moving forward on a tracking device, but the camera is a bit jumpy – whats the best way to stabilise it so the ending shot is a smooth forward motion?
    Roland R. kahlenberg replied 17 years, 11 months ago 3 Members · 4 Replies
  • Mark
    October 17, 2008 at 1:35 pm
    If you have a point in the shot that stays in the entire shot, then you can track that point and apply tracking to only Y…if you do not, then you may need to cut the clip up and do the tracking in segments, then adjust the Y position of each segment to match the other segments…
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Phil Beastall
    October 17, 2008 at 1:46 pm
    But what if the point is in the shot but is growing in size because the camera is getting closer?
  • Mark
    October 17, 2008 at 2:02 pm
    Then I would think that you need a 3d tracker, as you would need to get the z position…. I am really not all that sure, as I have never had to do this.
    Mark
    Mark Harvey
    Senior Editor
  • Roland R. kahlenberg
    October 18, 2008 at 10:18 am
    Grant Swanson has a COW Tutorial on this issue Motion Stabilization (while retaining camera movement)
    Cheers
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
