Activity › Forums › Adobe After Effects › stabilisation keyframes created
  • stabilisation keyframes created
    Posted by Roger Burton on July 22, 2005 at 8:59 am
    Me again…so I kind of sorted the problem I had with stabilisation…but, out of interest, just what are all the keyframes that are created…and are they needed…can I get rid of some or shall I just leave them all alone…eg: “Feature Centre”, “Confidence”, “Attach Point” and “Anchor Point” (obviously anchor point is important)…thanks for your help…Roger
    Roger Burton replied 21 years, 2 months ago 2 Members · 2 Replies
  • Aharon Rabinowitz
    July 25, 2005 at 5:18 pm
    You should have 2 sets of keyframes, once you;ve applied the stabilization.
    1) A proeprty called Tracker with the trackers listed, and all of their keyframes.
    2) Anchor Point, rotation, scale keyframes (You may have 1, 2 or all 3 of these depending on how you tracked it.)
    Once you’ve applied the stabilization (by hitting Apply), you can delete your tracker and all of it’s keyframes.
    Unless you render out your new stabilized version of the video, you CAN NOT delete the Anchor Point, rotation, or scale keyframes. They area ll that is holding your layer in place. Otherwise it returns to it’s original state.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Roger Burton
    July 29, 2005 at 2:08 pm
    Thanks Aharon…that’s good
