Activity › Forums › Adobe Premiere Pro › Stabilisation-1st or last in post render chain?
Posted by Jim Bachalo on July 3, 2011 at 11:44 pmHi
Can someone tell me when it is best to stabilize your footage, BEFORE CC and grading and other fx or AFTER?Local is the new global
Mark Lawrence replied 15 years, 2 months ago 3 Members · 2 Replies -
Todd Kopriva
July 4, 2011 at 12:06 amI always do it first.
For one thing, rotoscoping is _much_ easier on stabilized shots.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Mark Lawrence
July 4, 2011 at 12:16 amI have found that the optimal effect chain order changes according to content. For example, sometimes stabilization has worked more effectively on a graded scene, especially if it was done to enhance contrast or correct illegal levels. However, more artistic or aggressively graded scenes sometimes confuse the algorithm and therefore it is better to stabilize beforehand. So it’s trial and error.
There’s one concrete rule though: if you’re using noise reduction, always do that prior to stabilisation as it helps the algorithm to concentrate on wanted detail and not on random noise.
