Activity Forums Adobe After Effects Stabalizing shakey Jib Shot
  • Jonny Webb
    June 27, 2012 at 8:44 am
    hi, i’ve been using Warp Stab a lot lately and i’ve found it to be a tempermental beast. Sometimes its works really well, other times it sucks, and thats on the same clip!
    I found that you need to fiddle with the settings a lot. In the Warp’s settings make sure you have “Smooth Motion”, and try turning up the smoothness from default 50% to say 70%.
    your “method” needs to be “subspace warp”
    “framing” is whatever suits your needs.
    Also, try experiemnting with just a dozen or so seconds of footage as Warp can take a long time to calulate the changes.
    Hope that helps, Jon
  • Michael Szalapski
    June 27, 2012 at 11:55 pm
    And, if all the tweaking in the world won’t fix it (even though it should), you could always try the legacy stabilizer.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Darby Edelen
    June 28, 2012 at 2:37 pm
    I was able to get a good result on your clip with the Warp Stabilizer by using the Position, Scale, Rotation method for the stabilization.
    Darby Edelen
