Activity Forums Adobe Premiere Pro Stabalize a clip ??
  • Stabalize a clip ??
    Posted by Pjoconnell on July 31, 2005 at 3:50 am
    I have some hand-held wedding footage that I’d like to use, but it is not as steady as I’d like. Is it possible to smooth/stabalize a short clip a bit? Is there a plug-in for this effect? I can’t find anything in the list of effects nor in the Index or Search in Help.
    THNX/PJO
    Pjoconnell replied 21 years, 1 month ago 4 Members · 5 Replies
  • Pentti Kakkori
    July 31, 2005 at 5:13 am
    Premiere Pro 1.5 came with 2d3 company’s SteadyMove-plugin. Effects>VideoEffects>2d3>SteadyMove. It may help you.
  • Tim Kurkoski
    August 1, 2005 at 4:04 pm
    Agreed. I’ve been playing with it a little lately. While it’s a limited version compared to the full SteadyMove Pro, the default settings always seem to work fine.
    BTW, you need to install the plug-in from the Premiere Pro 1.5 CD.
  • Pjoconnell
    August 1, 2005 at 4:57 pm
    Thanks for the info.
    However: I’ve tried to find SteadyMove on the CD, with no success. I can’t find it on the disk with Windows Explorer, and I tried the Install window and the Explore CD Content button — no results. I Searched the CD and the Adobe Premiere Pro 1.5 folder on the HD — no results. I also looked in the Plug-ins folder on the HD and couldn’t find anything. I then ran the Repair cycle from the CD (thinking there might be a window for installing additional features) with no results. I am running from an Educational Version CD (because that’s who I’m working for), but that often doesn’t make a big difference. Any idea how I can find/install it?
    THNX/PJO
  • Steven L. gotz
    August 1, 2005 at 5:21 pm
    It does not come on the education CD.
    https://www.2d3.com
    Go to the support area, Find Answers, FAQs and look for Steadymove.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Pjoconnell
    August 1, 2005 at 7:52 pm
    Many, many thanks. I’ll try it.
    PJO
