Activity Forums Apple Final Cut Pro SSTP-SQ into FCP X
  • SSTP-SQ into FCP X
    Posted by Michael Sanders on September 5, 2015 at 4:53 pm
    Hi All.
    I did some shooting on my F55 in SSTP-SQ the other day.
    We ran it through Catalyst Browse to convert it into pro-res and into FCP X, but I was wondering if there’s more a streamlined workflow.
    Can’t seem to find any plug-in on the Sony site.
    Michael
    Michael Sanders
    London Based DP/Editor
    Jeremy Garchow replied 11 years ago 2 Members · 3 Replies
  • Jeremy Garchow
    September 5, 2015 at 6:55 pm
    Load the codec and drag in the MXF files and away you go.
    https://www.sonycreativesoftware.com/srpm-10
  • Michael Sanders
    September 6, 2015 at 9:10 am
    Thanks Jeremy. My mistake was I loaded the CODEC but I was trying to load the files directly from the card. Dragging the MXFs in worked perfectly.
    Cheers.
    Michael Sanders
  • Jeremy Garchow
    September 6, 2015 at 9:15 am
    It’s the same with XDcam or XAVC files from the F series Sony cameras. For whatever reason, Apple took over the Sony import plugin, and by doing so, the plugin is tied in to the install of FCPX. When using the import window, FCXP tries to wrap everything to ProRes (which is really annoying since MXF is supported so nicely in FCPX now). Instead, dragging the clips from the Finder allows to read the MXF files directly without having to rewrap to .mov, which just wastes a lot of disk space. I find performance in X with all flavors of Sony codecs to be really great, and no difference than ProRes.
    I have found a way to remove the Sony import plugin without any damage to X (and can always be replaced if needed). This allows direct import (and leave in place options) for Sony MXF media though the FCPX import window.
    Jeremy
