Activity Forums Storage & Archiving SSD’s in RAID 0 or a Pro SSD?
  • SSD’s in RAID 0 or a Pro SSD?
    Posted by Eli Singer on October 26, 2016 at 12:34 pm
    I have encountered questions like this all over the place but I’m asking something a little different that i couldn’t find an answer to.
    the intended setup is for video editing in premiere, mostly HD but will get some 4k work as we go along.
    I thought about going with this setup:
    Samsung 850 EVO 250GB- OS drive/scratch
    Samsung 850 Pro 1TB / Sandisk Extreme 960GB- Media/scratch
    I’ve been suggested to replace the expensive pro 1TB drive for 2 500GB EVO drives in RAID 0 to get better performance for less money.
    In theory it sounds good but the reason i wanted to go Pro in the first place was because i wanted consistent sequential reads that will be high enough to support multiple streams in a complicated timeline.
    I know that the EVO drops like hell under that load. But will 2 striped EVO’s do it?
    Just to get it out of the way, of course all the media will be backed up to different drives so the SSD’s are just for “hot” projects.
    I’m still undecided as to the question of adding another small SSD (EVO?) just for the scratch…
    I don’t intend to go 950 pro or 960 pro and stuff like that due to price so let’s skip that.
    Thanks in advance,
    Eli
    Alex Gardiner replied 9 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jon Schilling
    October 27, 2016 at 9:06 am
    Eli.
    Are the SSD’s made/approved for being “striped”? I’ll guess not likely, (most aren’t).
    If you don’t know, don’t do it, you’ll likely cause more harm than good.
    Jon Schilling
    Sales and Marketing
    GB Labs
    23890 Copper Hill Drive -Suite 103
    Valencia, CA 91355 – USA
    e-Mail: Jon@GBLabs.com
    Mobile: +1 661-495-8641
    Skype: cgijon
    http://www.gblabs.com
  • Eli Singer
    October 27, 2016 at 9:21 am
    What do you mean approved for being “striped”?
    People are using them in RAID 0 all the time, question is, will it do better in an editing environment than a single Pro drive?
  • Alex James
    November 2, 2016 at 11:34 am
    Hi Eli,
    “Disk striping is the process of dividing a body of data into blocks and spreading the data blocks across multiple storage devices, such as hard disks or solid-state drives (SSDs). A stripe consists of the data divided across the set of hard disks or SSDs, and a striped unit, or strip, that refers to the data slice on an individual drive.” Ref: https://searchstorage.techtarget.com/definition/disk-striping
    Basically it means dividing the data over a number of drives (i.e a RAID) So multiple HDD drives can be accessed at once for high speed data transfer).
    I’ve been looking for a similar solution to yourself but for a different purpose. Check out my post:
    https://forums.creativecow.net/thread/381/944
    I’d Just buy one of these if you can afford:
    SANDISK EXTREME 900 PORTABLE SSD
    https://www.sandisk.com/home/ssd/extreme-900-ssd
    Gives you up 2TB storage which will be fast, secure and highly portable. Very high speed data transfer and doesn’t require external power.
    A RAID enclosure may be a better option to with if you require a larger drive and you should be able to do it a little cheaper.
    Regards,
    Alex
    Alex James
    TINY ARK
    http://www.tinyark.com
  • Eli Singer
    November 2, 2016 at 11:44 am
    I know what striping is ?
    I was asking what does the expression “approved for being striped” means…
    In any case, the SANDISK EXTREME 900 PORTABLE SSD is actually nothing more than 2 Sandisk Ultra II in Raid 0 stuffed in an enclosure.
    Question is, will it do better in an editing environment than 1 Sandisk Extreme or Samsung 850 Pro?
    Eli
  • Alex Gardiner
    November 3, 2016 at 11:47 am
    My question to you would be how you handle the RAID side of things?
    I don’t know of many (RAID aware) filesystems or hardware RAID implementations that can properly TRIM SSDs… Normally you have to rely on built in garbage collection. Happy to be wrong, but fairly sure I’m right.
    NB: ZFS on BSD can issue the command to the underlying devices. Don’t think ZOL can do it (yet).
    Things to think about:
    * In the real world we found that SSD based ZFS (ZOL) pools don’t really slow down when writing large files. Point in case, we have compact 1U indiestor servers on a fleet of OB trucks. As yet there has been no real need to secure erase.
    * I don’t know of (m)any SSD’s that are built with striping in mind. There are however enterprise grade SSDs that are SLC based (not MLC). They usually have caps for retaining data in the case of an unclean power down (makes them suitable for cache devices in certain types of storage pool). These products tend to have a greater endurance rating too.
    * FWIW my experience has been that the endurance of even lower end MLC type SSDs (Samsung Pro etc) seems to be remarkable.
    To conclude, I’m not sure how much this helps, but ostensibly it seems that no – I don’t there is no such thing as an SSD that it setup for striping, per se.
    IMO just get one big/better quality/higher IOPS SSD and back it up.
    Thats my view.
    Storage Engineer
    alex@indiestor.com
  • Eli Singer
    November 4, 2016 at 6:10 am
    I won’t be using it in ZFS, it will be connected directly to the main editing machine in RAID.
    I have a FreeNAS server all the data that I’m just setting up separately.
    I am also not concerned with data loss during power failure. All the data is backed up and these drive/s are only meant to work as working drives for hot projects.
    Looks like I’ll be going Pro, can’t seem to find any concrete info on the matter…
    On a different subject, what are your thoughts regarding another SSD for Scratch Disk?
    Eli
  • Alex Gardiner
    November 4, 2016 at 7:24 pm
    Then in my opinion Evo, Pro or similar will be fine. You’re unlikely to kill them as a single user. If they slow down secure erase and start over.
    Generally the more expensive (pro/enterprise) drives have better IOPS figures, which is less important if you’re just doing sequential reads/writes… maybe more so as a cache drive for lots of little bitty files.
    Pretty sure there aren’t RAID specific SSDs (would love to see a link if there are). HDDs yes – TLER and such + designed for density/vibration sensors etc etc… SSDs though I’m not convinced other than the logic that enterprise class drives are probably going to have a better MTFB rating.
    Actually I don’t think you can screw this up.
    As above, the weakest link will be how you implement the RAID. OS X + Windows have crap offerings OTB, unless you use a hardware based controller from LSI/Areca/Adaptec etc.
    Storage Engineer
    alex@indiestor.com
