Activity Forums Adobe Premiere Pro SSD vs RAID?
  • SSD vs RAID?
    Posted by Max Baker on February 27, 2016 at 5:58 pm
    So, Adobe recommends RAID configuration for working uncompressed video in Premiere Pro, but will a single SSD 3.0 handle the workload given its faster performance over a standard HDD?
    Max
    Tero Ahlfors replied 10 years, 6 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    February 27, 2016 at 6:39 pm
    SSD’s are fast but there are still pros to using RAIDs.
    -Redundancy. When your SSD fails, that’s it. It’s done and your data is gone. If you have a RAID5 one drive can fail and it’s still usable and you can rebuild. On a RAID6 two drives can fail and you still can rebuild that.
    -Price/space. Larger SSDs are pretty expensive and small. When dealing with uncompressed stuff (especially at higher resolutions/framerates) a terabyte won’t cut it. You can get pretty big volumes on a RAID setup pretty cheaply.
