Activity › Forums › Apple Final Cut Pro Legacy › Squished exported jpeg
  • Squished exported jpeg
    Posted by Chris Guinto on January 27, 2010 at 2:24 am
    I needed to export a single clip from my timeline within FCP for a jpeg. This I know how to do, though my final product is always squished and distorted. My frame size in FCP is 1280×1080. I find that when I shrink my frame size down by exactly half and then drag a clip out for a jpeg, it looks perfect…which doesn’t make any sense to me. I’ve been exporting it under ‘Quicktime conversion’, and then I click on ‘still image’.
    Any ideas?
    Chris
    Chris Guinto replied 16 years, 8 months ago 3 Members · 3 Replies
  • Rob Grauert
    January 27, 2010 at 4:05 am
    You’re doing it right: File > Export Quicktime Conversion. Select “Still Image” from the drop-down menu.
    But when that image is exported, bring it into Photoshop and change the Pixel Aspect Ratio to match the Pixel Aspect ratio of your footage.
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • John Pale
    January 27, 2010 at 7:16 am
    Your footage is DVCPRO HD. This is an anamorphic format… The pixels are not square. The image is 1280 pixels wide, but stretches to display as 1920. Computers display still images with square pixels, so you need to stretch the image in Photoshop to 1920 x 1080.
  • Chris Guinto
    January 28, 2010 at 2:23 am
    Worked like a charm! Thanks guys.
    Chris
