Activity Forums Apple Final Cut Pro Legacy Squished DV footage (DVX100A 24pA)
  • Squished DV footage (DVX100A 24pA)
    Posted by Rudolf Mcclain on December 9, 2009 at 4:32 am
    Hello,
    Just digitized dvx100a 24pA footage following FCP7 guidelines.
    Digitized just fine.
    But everything seems to default to 3:2 the footage and sequence windows show a squished image (4:3 squished to 3:2)
    I’ve been able to go in and manually change a bunch of settings to get the sequence to show 4:3 but it outputs (default) to quicktime stretched to 3:2.
    I would love to know how to setup a 4:3 projects, sequences, clips
    Any pointers, links or references would be much appreciated.
    Howard Ferguson replied 16 years, 8 months ago 3 Members · 19 Replies
  • 19 Replies
  • Howard Ferguson
    December 9, 2009 at 6:49 am
    Hi Rudolf,
    I’m sorry to say I don’t have an answer for you.
    I think I’m having the same problem right now.
    Except I’m in 24p.
    There doesn’t appear to be a setting that does not Warp the aspect ratio.
    In attempt to fix this, I created a 4:3 custom Capture Preset setting, but it has the same result as the others.
    Also, my Preset sets Anamorphic to OFF, but the generated QT file it is ON.
    My Preset Frame Size 640×480, but the generated QT file is 720×480.
    My Preset sets Pixel Aspect to Square, but the generated QT file is NTSC-CCIR 601.
    (And here is no Video Playback setting that is 4:3 ratio.)
    I’ve tried an array of Capture Preset settings but-All footage Captured from the DVX100A results in a stretched out image in the Quicktime movie the Capture generates.
    What was originally a Letterbox image (4:3) is stretched out to a 720×480 Quicktime movie.
    Stretched out wider than the image appears in the Log and Capture monitor, or the camera monitor.
    I can change various settings in Final Cut to put those QT movie clips back in the proper aspect for use in Final Cut, but-
    I’m still trying to discover how to generate a proper QT movie created from the Capture function, coming in from the DVX100A-
    A generated Quicktime movie that is the proper aspect ratio from the start, in the Capture generated Quicktime files.
    Any help with this would be wonderful !
    I’d greatly appreciate learning what I’m doing wrong.
    Howard Ferguson
  • Rudolf Mcclain
    December 9, 2009 at 7:19 am
    Thanks for posting. Sounds like what I’ve gone through.
    I have been able to export a proper 4:3 quicktime movie despite the stretched image in FCP.
    I’ll post if when I get answers. I thought since it is such a popular camera it would be easy to manage in FCP 7
    cheers
    Rudy
  • Bret Williams
    December 9, 2009 at 9:03 am
    DV is 720×480. You can’t change that on capture. The pixels of DV, like most SD sources are not square, they are rectangular. The computer displays them pixel for pixel, and since the pixels on the computer are square, you see a squashed image. If you wish the QT to playback as 4:3 , change it’s playback setting in QT Player to 640×480 , or export it as 640×480 as something else like h.264. DV files have to be 720x480z.
  • Howard Ferguson
    December 9, 2009 at 10:51 am
    Hi Bret,
    Thank you very much for this information !
    And here is why.
    My approach to fixing this situation with the QT files has been to:
    Make a Setting in Compressor to adjust the Aspect/Size, and some other stuff-
    And running them through it.
    What is the highest resolution solution to this situation ?
    Thanks very much for all this help !
    Howard Ferguson
  • Howard Ferguson
    December 9, 2009 at 10:53 am
    Hi Rudy,
    That’s very interesting.
    When you say-
    What do you mean by Export ?
    I’m guessing you mean an Export a movie from Final Cut ?
    Not a Capture from the DVX100A ?
    Are your QT movies created at Capture not “Squished” ?
    The QT movies in your Capture Scratch Folder ?
    I’m really glad you’ve asked these questions !
    Cheers !
    Howard Fergusion
  • Rudolf Mcclain
    December 9, 2009 at 4:56 pm
    Great.
    Thank you Howard. Much appreciated.
    The captured clip is 720×480. So that means that everything is fine.
    But… how can I change the view in FCP7 to view it as the 4:3 while editing.
    Thanks.
  • Howard Ferguson
    December 9, 2009 at 6:06 pm
    Hi Rudolf,
    I’d suggest looking under the Edit menu, at:
    Edit > Item Properties > Format
    There is an option for Anamorphic there.
    Unlike most of the properties, you can change the Anamorphic setting in this window. If it’s checked, it’s ON. Click that check to Uncheck, and turn it OFF.
    I find that every Capture from my DVX100A requires turning OFF the Anamorphic in this way.
    It seems like a very odd default setting, and I haven’t found a way to set the Default to OFF yet. I’d like to know how to do that.
    The Capture Preset does not have an option for Anamorphic
    It’s very odd that the Anamorphic setting does not appear in the Browser window.
    Great to discuss this stuff !
    Howard
  • Howard Ferguson
    December 9, 2009 at 6:27 pm
    Hi Rudolf,
    I’m very interested in precisely what your Capture Settings are.
    My QT movies always come into Final Cut with their Anamorphic errantly turned ON. And I haven’t found a way to keep that from happening with the QT files.
    Quicktime v10.0 (51) doesn’t have an Anamorphic control.
    Thanks !
    Howard
  • Rudolf Mcclain
    December 9, 2009 at 7:17 pm
    Thanks all.
    Capture is fine.
    I uncheck ANAMORPHIC for my sequence and drop the clip in. I get the error saying my clip differs from the sequence settings, accept adjustment. go back into the sequence settings and uncheck ANAMORPHIC again and the sequence plays just fine.
    two things. The LEFT viewer window doesn’t match the aspect ratio of the sequence window. The clip in the left (the same clip that is in the sequence) is squished flatter than 720×480.
    second. When i drag a new sub clip (mark in and out) of the original clip to add a second clip to the sequence, the second clip (wich is a subclip of the first clip) is squished the same as the viewer (more squished than 720×480)
    help.
    Thanks!!!
    Best,
    Rudy
  • Rudolf Mcclain
    December 9, 2009 at 7:36 pm
    ok. maybe if I lay it all out I’ll see what I’m missing….
    I shot DVX100a 24pA and used letterbox crop (not squeeze) so it just adds black bars to top and bottom of the 4:3 image.
    Captured DV NTSC 48 KHz Advanced pulldown removal
    The captured clip is 720×400 (found information from the captured file using finder) and that’s fine.
    Created a new sequence: DV NTSC 48 KHz – 23.98
    Drop clip in and receive error: “attention this clip does not match this sequence’s settings…. Change sequence settings to match the clip settings?” I choose yes.
    It looks squished in the sequence window (squish matches the viewer (LEFT) window)
    I say hmmmm…. I’d like to work with this sequence in a not so squished way.
    so I go into the sequence’s settings and uncheck ANAMORPHIC and the sequence window looks fine.
    now the left window view doesn’t match the right. Left squished, right not.
    I make a subclip of the original clip and drop that in after the first clip in the sequence.
    the sequence plays the first clip fine and the second clip squished.
    Thanks.
