Activity Forums Apple Final Cut Pro Legacy Squeezed still image with DVCpro HD
  • Squeezed still image with DVCpro HD
    Posted by Bronek on September 25, 2006 at 5:44 pm
    Ahhhh-
    When I try to export a still frame using the DVCPro HD codec, the image comes out squeezed! What am I doing wrong? I’ve tested other formats and they look just fine.
    Help!
    Bronek
    Jeremy Garchow replied 19 years, 12 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    September 25, 2006 at 5:59 pm
    If you are working in 720p, the image is squeezed to 960×720 when recorded to tape, that’s normal. You will need to bring the still up to 1280×720 in photoshop.
    If you are working 1080, then the size is 1280×1080 in which case you would bring the size up to 1920×1080 in photoshop.
    Jeremy
