Activity › Forums › Compression Techniques › squeezed conversion 16:9 to 4:3
  • squeezed conversion 16:9 to 4:3
    Posted by Lasse Laursen on September 27, 2009 at 3:32 pm
    I have a 10 second spot shot in Panasonid HD (960X720 50fps)
    The client needs the final spot in the following specs.
    Mpg2 program stream (audio and video together) field order B (.mpg)
    720:576 pixels, 25 fps. (Pal DVD) 24 bit, 4:3
    Gop: 1
    Gop : 12
    I-Frame distance: 12
    Reference distance: 3
    I have managed to find and adjust all of the above besides I-Frame distance, Reference distance and field order inside compressor. Are they possible to set from compressor?
    The final question, and this might be a bit n00b, but when coverting my 16:9 footage (960X720 50fps) to 4:3 (720X576 25fps) my export gets squeezed. I want to keep the aspect ration and just have the exported mpg2 file letterboxed.
    I hope i make just a tad of sense.
    Best regards
    /Lasse
    Very nice forum )
    Daniel Low replied 16 years, 12 months ago 2 Members · 1 Reply
  • Daniel Low
    September 29, 2009 at 12:58 pm
    720×576 can contain either a 4:3 or 16:9 frame aspect. Simply select 16:9 as the desired target in compressor, it’ll look squashed until you view it through a DVD player, VLC etc.
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today
