Activity › Forums › Compression Techniques › squeeze won’t read DVCPro50 format
  • squeeze won’t read DVCPro50 format
    Posted by Michael Duff on August 22, 2006 at 11:27 pm
    hi guys – I’m having some more Squeeze trouble 🙁 I have a quicktime file that is 30Gig using the DVCPro50 codec. I need squeeze to compress it down into an MP4 or something. But squeeze says that the format is not compatible! I tried installing a codec pack that included a DVCPro codec but still no luck…… does anyone have any suggestions?? thanks
    Ed Dooley replied 20 years, 1 month ago 2 Members · 3 Replies
  • Ed Dooley
    August 23, 2006 at 8:39 pm
    On Windows? (which doesn’t support DVCPro natively)
    Was the codec you installed DVCPro50 or plain DVCPro? (because they’re not the same thing)
    You can buy the codec for PCs though, or try the free Avid codec for Windows 2k and XP:
    https://www.avid.com/onlineSupport/supportcontent.asp?productID=92&contentID=3555&typeID=2
    Ed
  • Michael Duff
    August 23, 2006 at 11:33 pm
    hi, yeah it’s on windows. ummmm, the I think it was a DVCPro50 codec, it was the only one I could find online, I think it was a matrox one(?)
    so the Avid download includes a DVCPro50 codec?
  • Ed Dooley
    August 24, 2006 at 1:59 pm
    Matrox *does* offer a DVCPro50 codec. I haven’t personally used the Avid codec for DVCPro 50
    video on a PC, but they do include DVCPro50 support, and the link I sent you allows you to use
    Avid’s codecs in other applications, so you should be good to go.
    Ed
