Activity Forums Apple Final Cut Pro squeeze vs letterbox on DVD
  • squeeze vs letterbox on DVD
    Posted by Jeffrey Carter on October 30, 2012 at 7:56 pm
    Usually, when I make a DVD from HD material via compressor and DVD SP, I can set it so that it squeezes the video instead of letter boxing it.
    Using the built in ‘share’ setting to create a DVD straight from FCPX, it gives you no options and just letterboxes. Does anyone know of any tricks to get a squeezed DVD?
    For quick one-offs of DVD’s that I don’t want to bother authoring (especially when DVD SP stops working) it would be nice if we could have a little more control…
    Jeffrey Carter replied 13 years, 10 months ago 2 Members · 2 Replies
  • Bret Williams
    November 2, 2012 at 4:09 pm
    I’ve made DVDs from X and it didn’t letterbox. I’m not sure there’s even an option. There is no reason I can think of to Letterbox DVD content. Letterbox is performed by the DVD player on playback if it has 16:9 material and has a 4:3 screen connected.
    You sure you’re seeing letterbox and don’t just have the player setup for 4:3?
  • Jeffrey Carter
    November 4, 2012 at 8:48 pm
    Thanks for the reply! No, the player is the same as I always use. When I author a DVD using DVD SP, I set the display type to 4:3 and that squeezes the image so I can un-squeeze on the player to watch on my HD TV.
    When I burn a DVD straight from the share menu of FCPX using Apple’s DVD preset, it creates a letterbox image. There seems to be no presets that I can see.
    In the instance you’re referring to, are you using the share preset and are you going from HD original to an SD DVD?
    Normally I author through DVD SP, but it would be nice for quick ‘one-offs’ to be squeezed so I can use the full image.
