Activity Forums Compression Techniques Squeeze resize issue
  • Squeeze resize issue
    Posted by Tim Mclaughlin on December 3, 2008 at 8:57 pm
    I’m trying to make a 800×450 mp4 from a 1280×720 file.
    Squeeze is forcing my file to be 800×448, even when I check “unconstrained”.
    I’m using the Main Concept encoder, AVC Profile is set to “High”.
    When I use Compressor for the same job, I can set 800×450 easily – but without as many options, of course.
    What am I missing?
    Tim McLaughlin
    Avid and Final Cut Editor
    Daniel Low replied 17 years, 9 months ago 2 Members · 1 Reply
  • Daniel Low
    December 3, 2008 at 11:44 pm
    Squeeze is (correctly) constraining the dimensions to be exactly divisible by 4, 8 or 16.
    Quicktime H.264 isn’t so fussy and as such would result in a lower quality result.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
