Activity Forums Compression Techniques Squeeze Problem
  • Squeeze Problem
    Posted by Richard Walton on June 7, 2006 at 6:28 pm
    MacBook Pro 17″
    FCP Suite 5.1
    Sorenson Squeeze 4.0.3
    I just installed SS Compression Suite 4.0.3 When I attempt to use the “INPUT” function “Import” all my QT files are grayed out. If I drag a QT file onto the interface I’m able to choose a “Filter” but when I attempt to pick a “Format & Compression”setting the format highlights but I can’t use the “Apply” button (grayed out)
    I’m a newbie with this software so it’s likely I’m missing something fairly basic.
    Richard Walton replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
