Activity Forums Compression Techniques Squeeze : mov –> rmvb = empty file (0k)
  • Squeeze : mov –> rmvb = empty file (0k)
    Posted by Ignatius Gorin on May 21, 2007 at 11:29 am
    I just purchased Squeeze and need to encode a Real 8 movie from a self contained QT sequence (output from FCP).
    I imported the sequence, tried a preview. The preview.rmvb file is ok, launches in RealPlayer, etc.
    Then I start the job, but after it’s done, the rmvb output file is empty (0kb), so RealPlayer says “unsupported format”.
    Any idea ?
    This is urgent.
    OS-X 10.4.9
    Squeeze 4.5.500.1
    Preset used : 768k_Stream / Real 8 / 432×240 (because the input is 1080i), 2-Pass VBR.
    TIA.
    Ignatius Gorin replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
