Activity › Forums › Panasonic Cameras › squeeze mode & anamorphic adapter
Posted by Shaun Styles on May 31, 2005 at 7:07 pmcan you really see a differnece between the sqeeze mode and the widescreen lens adapter, if you are shooting for video
thanxs shaunShaun Styles replied 21 years, 4 months ago 3 Members · 4 Replies -
Janet Turner
May 31, 2005 at 11:42 pmShaun –
Thank you for asking this question. As a new owner of a Panasonic DVX-100A, I have been wondering the same thing. I look forward to seeing the answers.
Grasshopper
Mike Mcneese
June 1, 2005 at 2:57 pmIt depends on what you are viewing the footage. If you are watching the footage from a DVD on a 27″ TV, then I’d say you probably would not be able to see much difference, if any. If you are going to film, or upconverting to HD, then the anamorphic adapter is a must, as you need the highest possible resolution you can get.
The difference is apparent upon close inspection, but the decision to go with an adapter depends on your budget, the final destination of your footage, and whether the adapter will make a difference to you and your production.
On the other hand, I chose to not use an anamorphic adapter with my DVX, because of some aberrations the adapter causes. If I really need the adapter, a local guy will rent one to me. Otherwise I use the digital squeeze, and I’ve been happy with it.
Janet Turner
June 2, 2005 at 3:08 amMike –
Thank you for taking the time to provide some insight into this mode of shooting.
Grasshopper
