Activity Forums Panasonic Cameras Squeeze Lens?
  • Squeeze Lens?
    Posted by Rafi Bagramian on March 19, 2008 at 6:16 pm
    I have a Panasonic AG-DVC80 Camera, (Looks exactly like the DVX100A but has less of the functions.)
    The DVC80 doesn’t have a Squeeze Mode like the DVX100A. Is there a Lens which can be added to the 80 so it will shoot in the same squeeze mode as the 100A?
    If so, what’s it called and is it commonly available?
    I’d like to be able to use Footage from both Cameras (In Squeeze Mode) and Edit them interchangeably without problems.
    The Squeeze Mode seems to be the simplest and least expensive way of achieving True Wide Screen Shots.
    Thanks You.
    Noah Kadner replied 18 years, 5 months ago 2 Members · 1 Reply
