Activity › Forums › Compression Techniques › Squeeze crashes
  • Squeeze crashes
    Posted by Tom Nelson on March 28, 2008 at 7:37 pm
    I’m trying to compress an FLV and a SWF from Squeeze 4.3 off of an uncompressed QT file out of Avid. When I try to adjust the presets, no codecs show up for audio. When I try to compress as-is, Squeeze crashes. I’ve already tried uninstalling and re-installing Squeeze – no luck. Any ideas?
    FYI – I’ve done the same process (I believe it’s the same process) on other edit suites with good results.
    -Tom
    Tom Nelson replied 18 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
