Activity Forums Compression Techniques Squeeze crashes
  • Squeeze crashes
    Posted by Tom Nelson on March 28, 2008 at 7:38 pm
    I’m trying to compress an FLV and a SWF from Squeeze 4.3 off of an uncompressed QT file out of Avid. When I try to adjust the presets, no codecs show up for audio. When I try to compress as-is, Squeeze crashes. I’ve already tried uninstalling and re-installing Squeeze – no luck. Any ideas?
    FYI – I’ve done the same process (I believe it’s the same process) on other edit suites with good results.
    -Tom
    Del Chapple replied 18 years, 5 months ago 2 Members · 1 Reply
  • Del Chapple
    March 28, 2008 at 9:53 pm
    Is the squeeze on the avid? if not you might need to load the avid codec on the squeeze computer..
    d
    you cant hear my inner voice scream… can you..?
