Activity Forums Compression Techniques Squeeze Color Issues….
  • Squeeze Color Issues….
    Posted by Dean Stapleton on December 19, 2009 at 10:02 pm
    Hi folks, I’m new to editing and compression so forgive me if this is a stupid question!
    I’m running a Mac Pro Intel system w/two 23″ Apple Displays. Working with Final Cut Pro 7 and a newly purchased version of Squeeze 6.
    So, I take my rendered Final Cut Pro file (.mov) and import it into Squeeze. I immediately notice a huge difference in the color & gamma of the file as viewed inside of the Squeeze preview window. It’s darker and redder than the original rendered .mov file that I imported. So I begin to alter the color & gamma using the filters inside of Squeeze…..until I get it where I think it looks good and then I hit the Squeeze button to begin to encode the clip to MP4 (MainConcept H.264). Once the clip has encoded, I open it inside Quicktime and it looks nothing like the preview that I saw inside of Squeeze. Now I’m banging my head against the wall trying to figure out what is happening here. I can’t find any type of color profile adjustments inside of Squeeze that can be adjusted to remedy this.
    My displays are color calibrated once a month (I’m a professional photographer by trade so I do this religiously).
    Any thoughts on what is happening here would be greatly appreciated. I have submitted a support ticket to Sorenson but don’t expect to hear from them until sometime next week.
    Do you think this is a Squeeze issue? A Quicktime issue? A codec issue? A Mac issue? Or an issue of me not knowing what the hell I”m doing : )
    Thanks a bunch!!!!
    Dean
    Daniel Low replied 16 years, 9 months ago 2 Members · 3 Replies
  • Daniel Low
    December 19, 2009 at 11:05 pm
    [Dean Stapleton] “So, I take my rendered Final Cut Pro file (.mov)”
    Using what CODEC?
    [Dean Stapleton] “I immediately notice a huge difference in the color & gamma of the file as viewed inside of the Squeeze preview window.”
    Never trust a preview.
    [Dean Stapleton] “So I begin to alter the color & gamma using the filters inside of Squeeze”
    Did you try leaving the colour and gamma alone?
    [Dean Stapleton] “My displays are color calibrated once a month”
    To what? Print and video use quite different calibration settings (much wide range for print).
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
  • Dean Stapleton
    December 19, 2009 at 11:22 pm
    1. The codec that I used for Final Cut Pro output was ProRes 422 (LT). Is there a codec that works better in Squeeze than others?
    2. I’m happy to not trust a preview but it seems to me that the preview is there for a reason. If it’s not to be trusted, why is it doing there? Squeeze has got nothing but raving reviews (as far as I can tell) and none of those reviews had anything critical to say about their preview system not being accurate. That will be a good point to bring up with the folks at Sorenson when I hear back from them. The videos on their site clearly show the guy making adjustments via filters while previewing the results in the Squeeze viewer.
    3. Did I try leaving the gamma & color alone? Yes, I did. The first time I compressed the file, I didn’t touch the gamma & color. I only adjusted it after I noticed such a huge difference in what I was seeing in the Squeeze preview window and the original .mov file.
    4. My displays are calibrated using the Sypder 3 system from Datacolor. Since computer monitors are subject to drifting over time, this helps keep my monitors color & gamma stable. I realize that this is not how professional editors calibrate their monitors for accurate color work, but this is fine for what I’m doing. I’m not sure how calibration could cause a .mov file to look one way inside of Qucktime and another way inside of Squeeze.
  • Daniel Low
    December 19, 2009 at 11:48 pm
    1. ProRes is good. (Bear in mind that you’re going from a colour subsample of 4:2:2 to H.264 of 4:2:0)
    2. Preview is a preview, nothing more than that. Think of it as draft copy, not a final proof.
    3. It’s normal to notice a shift, but not a ‘huge’ one, can you supply screen grabs? (Remember 4:2:2 to 4:2:0 heavily compressed)
    4. I’m extremely familiar with monitor calibration (I teach it). Calibration alone will not cause the shift, I was simply curious what you had calibrated you monitors to i.e. what RGB space, D65 or? Gamma 2.2 or 1.8? Etc.
