Activity › Forums › Adobe Premiere Pro › Squashed image problem – 16×9 v 4×3
  • Squashed image problem – 16×9 v 4×3
    Posted by Roberto Baggio on November 13, 2007 at 4:55 pm
    Hi All.
    I am trying to create a DVD with premiere and my JPEG images are ‘sqaushing’ when written to DVD.
    The goal is to play the disc on a 42inch Plasma screen. Should I use 16×9 or 4×3 pixel ratio to stop the images squashing? I do not want a black line top and bottom of the screen. I want a full screen image. Would this be because I am using the wrong pixels in PhotoShop – square instead of 16×9?
    I have also created a 3D animated logo (in Max 7) and this is also ‘squashing’ up.
    Many thanks in advance.
    Roberto
    Vince Becquiot replied 18 years, 10 months ago 2 Members · 1 Reply
  • Vince Becquiot
    November 13, 2007 at 5:48 pm
    If by “squashing” you mean “stretching”, your problem is probably that your plasma is always set to full screen, meaning all 4:3 DVDs get stretched instead of addding black bars on the side.
    If you want 16:9, you have to start with 16:9 and keep that same workflow all the way to final export. That means you have to work in 16:9 in SdMax, and in a widescreen project in Premiere.
    If you have to work with 4:3 in your 16:9 project, you’ll have to zoom it in until you fill the sides. That means you will lose the top and/or bottom and some quality.
    Vince
