Activity Forums Adobe After Effects squares randomly flashing in grid
  • squares randomly flashing in grid
    Posted by Eugene Constable on May 12, 2015 at 6:32 am
    I have a grid of dark grey squares on black.
    I need the grid to gradually come to life, as if being ‘powered =up’ by colured squares that randomly flash around the screen.
    trying to avoid doing this manually.
    I found this expression:
    holdTime = .5; //time to hold each position (seconds)
    minVal = [0.1*thisComp.width, 0.1*thisComp.height];
    maxVal = [0.9*thisComp.width, 0.9*thisComp.height];
    seed = Math.floor(time/holdTime);
    seedRandom(seed,true);
    random(minVal,maxVal)
    sort of works for the random pos, but I need the squares to only appear randomly within the grid x and y spacing and also flash on and off. If it helps it a 1920×1080 comp and I have 26 squares in the the height…
    I’m new to expressions any help greatly appreciated!
    Eug
    Stephen Mendenhall replied 11 years, 4 months ago 3 Members · 2 Replies
  • Walter Soyka
    May 12, 2015 at 4:37 pm
    I would probably approach this procedurally, with Fractal Noise, Levels/Curves/Exposure, and Mosaic.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Stephen Mendenhall
    May 12, 2015 at 6:21 pm
    The fractal noise/mosaic approach is tried and true. I usually go that route.
    Recently I had a project that needed a little more control, and the Rift script saved me.
