Activity Forums Adobe After Effects Square Visualizer
  • Marek Ištok
    May 19, 2014 at 5:21 pm
    Does nobody know this? 😀
    I knew it was hard to do, but there has to be a way.
  • Michael Szalapski
    May 20, 2014 at 1:54 pm
    It’s not hard to do, but it is time-consuming. As far as I know, you can’t do it with the built-in effects. You would need to use Sound Keys to create keyframes for solid layers or shape layers. (Or mess around a LOT in Audition to create a separate sound file at different frequencies for each bar.)
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
