Activity Forums Apple Final Cut Pro Legacy Square Pixel projects for web use, best workflow??
  • Square Pixel projects for web use, best workflow??
    Posted by Karim Daire on March 19, 2009 at 9:30 pm
    i am regularly doing clips lately that just get used for the web. Source Material is mostly DV, so up to now I used to work in a DV-PAL Sequence Setting and then compressed my finished Clip using compressor, Streamclip etc. to get into the final square pixel setting without fields for web delivery.
    Since I was pretty disappointed of the results regarding the de-interlaced final clips (especially on titles and graphics with jagged edges from the de-interlacing) I wondered which workflow delivers best quality here?
    If I mix DV-Material and After Effects Titles and Animations and know I will deliver in 640×360 pixels, is it more effective to work in a 640×360 squarepixel sequence in Final Cut and Deinterlace the Video and render animations in progressive square pixels??
    Which Codec is then best to use? I went nuts about the render times that haunted me in this workflow.
    I basically threw my DV material into a 640×360 sequence with square pixels, de-interlaced it and exported it to a Quicktime with DV Compression. That already took some time, now on importing and placing the rendered clip back in the sequence settings I exported it from I got a red bar and had to render it again in FCP to get playback…
    Which Codec would you use when setting up a sequence with the settings above and is the DV-Codec the problem with progressive square pixels or why can’t FCP playback a rendered, exported and re-imported clip in real time with matching sequence settings??
    Which workflow would you use to avoid jaggy edges in titles and graphics from the De-Interlacing of DV encoded material??
    Karim
    -Karim-
    Rafael Amador replied 17 years, 6 months ago 2 Members · 1 Reply
  • Rafael Amador
    March 20, 2009 at 1:38 am
    Hi Karim,
    Your workflow is OK.
    Just few little things:
    – You need to set your 640×360 sequence with field dominance: NONE.
    – Export your AE graphics as Progressive. No point to make them interlaced if they have to be de-interlaced.
    Edit in the codec you want but before rendering:
    – Set your sequence to ProRess.
    – Set “Render all YUV in High Precision”.
    – Set “Render Motion Effects: Best”.
    Export your ProRess 640×360-Progressive-Square pixels QT movie. If you are happy with it you only need to compress it for the web.
    BTW, use a good de-interlacer. Nattress is the only one that works in 10b in FC.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
