Activity › Forums › Apple Final Cut Pro Legacy › square pixel and 4:3
  • square pixel and 4:3
    Posted by Pau Perez on May 29, 2008 at 8:42 am
    Hi everyone. I suppose most of you work with NTSC, but I think I would have the equivalent doubts with that format as I have with PAL.
    This is the point: Isn’t PAL supposed to look 4:3 in it’s final square pixel look in computer?
    I mean, when I capture, the video has a flattened 768×576 look because of the non square pixel I suppose, although it says it is 720×576. So, looking flat it is 4:3. Now, when I compress it for example with the Flash encoder, it gains the non flatenned square pixel look and becomes really 720×576. But 720×576 is not 4:3. So the only way of having 4:3 in the computer is having it flattened?
    This drives me nuts.
    Pau Perez replied 18 years, 4 months ago 2 Members · 2 Replies
  • Tom Wolsky
    May 29, 2008 at 11:39 am
    Use your Flash encoder to resize the image to a 4:3 aspect ratio.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Pau Perez
    May 29, 2008 at 12:25 pm
    But if I do that, the image will be flat and short, not with its real proportions. It’s just that I thought it was possible to obtain 4:3 with square pixels conserving its real proportions. But either you have to cut or short the image.
