Activity Forums Adobe After Effects Square Pixel
  • Square Pixel
    Posted by Samuel Jacques on September 16, 2008 at 1:43 am
    hello.
    I know this has probably been asked before.
    But I don’t seem to totally understand the principle and I’d like to make sure I’m right on this.
    I need to do an animation in after effects and then I need to burn a typical dvd movie (with menu). That dvd will be seen on a computer screen.
    My guess would be to make my comp. with the preset “NTSC D1 Square Pixel”, 720×540.. so that nothing is stretched 10%.
    But, does that mean if I read the dvd on a tvscreen, the video would be streched ?
    So if I don’t want the whole thing to be stretched on a tvscreen, I need to chose “NTSC DV”, 720×480 nonsquarepixel?
    Or I am totally wrong ?
    thanks in advance.
    sam
    Samuel Jacques replied 17 years, 11 months ago 2 Members · 5 Replies
  • Darby Edelen
    September 16, 2008 at 5:18 am
    My recommendation would be to use the NTSC DV preset (720×480) throughout your workflow. DVD emulators on PCs are expecting to get DVDs that were created for viewing on a TV, and they’ll know how to handle them.
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • Samuel Jacques
    September 17, 2008 at 12:43 am
    hello
    thanks for the advice.. but it still don’t work. It still look stretched when I playback on a computer when I burn a DVD with the DV preset.
    I burnt it with Toast Titanium (osx).
    I don’t know if it’s the way I render my animation or the way I burn the DVD.
    I have tried to burn a dvd with this preset “NTSC D1 Square Pixel” and it showed up well on computer screen.
    So, since my dvd will probably be only read on a computer.
    Is it ok to use this preset?
    thanks!
    sam
  • Darby Edelen
    September 17, 2008 at 4:31 am
    It sounds like whatever you’re burning the footage with is treating it strangely. How are you encoding to MPEG-2?
    If it works the way you’re doing it, then I guess you should keep doing it that way 🙂 but something seems off about it
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • Samuel Jacques
    September 17, 2008 at 12:36 pm
    Hello
    Thanks for your help Darby!
    I finally get it to read correctly after burning.
    I was just rendering my animation in quicktime with the default setting.
    This time, in the video output, format options, I have switch to “DV/DVCPRO – NTSC”. I burnt that video and it works.
    Is it better to use mpeg2? If yes, is there a special preset to chose?
    Thanks alot
  • Samuel Jacques
    September 17, 2008 at 11:43 pm
    oh ok! I will do that way then.
    thanks alot for this precious advice Dave!
