Activity Forums VEGAS Pro Square format rendering for Facebook, etc.
  • Square format rendering for Facebook, etc.
    Posted by Rob Lindsay on January 3, 2018 at 9:27 pm
    I am trying to create a 1080×1080 format of a video just cut in 1920×1080 in my V13 system. It doesn’t seem to want to create an mp4 at those sizes. Main concept, the only choice I found that offers a custom aspect ratio that I can input 1080sq into, only seems to create a n mp4.tmp file that i can’t play. I’ve tried the XDCAM EX render choice at 1440×1920 and it seems to do nothing at all different from the original.
    is there a way to create a square HD file for Facebook?
    Thank you,
    Rob
    Vegas 13.453
    Dell Windows 10
    Intel6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
    Marco Baer replied 8 years, 7 months ago 2 Members · 10 Replies
  • 10 Replies
  • Marco Baer
    January 3, 2018 at 10:26 pm
    In VP13 rendering to MainConcept AVC when having set the size to 1080×1080 works fine here. You may need to start from the render preset “Internet-HD 1080p” and modify the size then.
  • Rob Lindsay
    January 3, 2018 at 10:55 pm
    Actually that is exactly what I did, and got a file rendered called “Jen_.mp4.tmp” which could not be played until I removed the TMP and then it was the original format of 16×9.
    Strange? Or am I missing something?
    Vegas 13.453
    Dell Windows 10
    Intel6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Marco Baer
    January 3, 2018 at 11:19 pm
    There should be no .tmp file in the end. This looks like rendered what not have been finalized.
    Also – did you ensure in the render window you unchecked “Conform frame size by source”?
  • Marco Baer
    January 3, 2018 at 11:25 pm
    It should mean: “… like rendering was not …”
  • Rob Lindsay
    January 4, 2018 at 2:08 am
    Yes, “allow source to adjust frame size” is unchecked.
    Vegas 13.453
    Dell Windows 10
    Intel6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Marco Baer
    January 4, 2018 at 11:14 am
    Any chance to show a screenshot of your render settings?
  • Rob Lindsay
    January 4, 2018 at 3:57 pm
    I will try to add a screen shot of the render settings below:
    Vegas 13.453
    Dell Windows 10
    Intel6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Marco Baer
    January 4, 2018 at 10:47 pm
    I just tested again with exact same render settings as in your screenshot and my rendered file is 1080×1080.
    But how do you check your video still is 1920×1080? Did you already try to analyze via MediaInfo?
    My guess is your result may also be 1080×1080 but with black bars on bottom and top because (of course) the video is neither stretched nor cropped to make the 16:9 format fit the 1:1 frame now.
    If that it is you need to further edit your timeline events, while cropping is the prefered method.
  • Rob Lindsay
    January 4, 2018 at 11:21 pm
    Here’s a screen shot of the frame after rendering at 1080×1080
    Still 16×9, just smaller than the normal 16×9 file and less than half the file size.
    I’m totally confused.
    Vegas 13.453
    Dell Windows 10
    Intel6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Marco Baer
    January 4, 2018 at 11:26 pm
    Please check the file via MediaInfo and see what it means for the frame size.
    Of course it would still look like 16:9 if you don’t edit the frame in any way. But it probably is not 16:9 but letterboxed 1:1. Try cropping your video events to a 1:1 frame size in the timeline before rendering.
