Activity › Forums › Boris FX Particle Illusion › S;pw Motion
S;pw Motion
Posted by Russ930 on December 27, 2006 at 3:48 amCan anyone tell me how to slow down the effect of a emitter? I am using the Space Explosion 2 effect and would
like to slow the explosion down.
Thanks in AdvanceAharon Rabinowitz replied 19 years, 7 months ago 3 Members · 3 Replies -
Tinger
December 29, 2006 at 8:51 amRussell,
What sometimes works is to increase the amount of frames in the project. Then play it back at normal rate.
Craig
Aharon Rabinowitz
January 3, 2007 at 10:37 pmyes and no. if any of the properties are animated, the animation will need to be scaled – select the property ancd right click in the timeline for the option.
Also – if the partricle shape is made from a sequnce of images that are playing, this won’t work because when you record at a higher frame rate it will cycle those images much faster. The only solution I know if is to make your own image sequences that account for this – so make an image sequence with more frames.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
