Activity › Forums › Web Design (WordPress, Joomla, etc.) › Spry submenu ie is horizontal vertical
Posted by Ester Juiwi on September 30, 2009 at 7:54 pmHello people! Such?
'm good here fighting the damn explorer. Pq no glared?
For the case, I just finished a website with a vertical submenu appears that the
Mr Internet Explorer choose to horizontal. It happens to you why?
I change something in code to avoid?Page (p if you want to see the code with firebug) is https://www.Fundacionanas.org
Thank you very much for your help. GreetingsDave Green replied 16 years, 10 months ago 3 Members · 2 Replies -
Fernando Mol
October 9, 2009 at 1:56 pmYour CSS defines if it’s horizontal or vertical. And in your site you have an horizontal CSS for your menu.
*Remember to share a link to your site and to rate the posts. This is a free service for you and for us.
Dave Green
November 20, 2009 at 10:19 pmThis is supposed to be a horizontal spry navigation bar with vertical submenus… I built the site with Dreamweaver CS3 and it works everywhere it’s been rested except on Internet Explorer. What have I done wrong? (I’m a graphics guy venturing out into code)
@charset “UTF-8”;
/* SpryMenuBarHorizontal.css – Revision: Spry Preview Release 1.4 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, an auto width box with no margin or padding */
ul.MenuBarHorizontal
margin: 0;
padding: 0;
list-style-type: none;
font-size: x-small;
cursor: default;
width: auto;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: https://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
ul.MenuBarActive
z-index: 1000;
/* Menu item containers, position children relative to this container and are a fixed width */
ul.MenuBarHorizontal li
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: left;
cursor: pointer;
width: auto;
float: left;
/* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarHorizontal ul
margin: -5 0 0 95%;
padding: 0;
font-size: 100%;
z-index: 1020;
cursor: default;
width: auto;
position: absolute;
left: -1000em;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
left: auto;
/* Menu item containers are same fixed width as parent */
ul.MenuBarHorizontal ul li
float: none;
background-color: transparent;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
ul.MenuBarHorizontal ul ul
position: absolute;
margin: -5% 0 0 95%;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
left: auto;
top: 0;
DESIGN INFORMATION: describes color scheme, borders, fonts
/* Submenu containers have borders on all sides */
border: 1px solid #CCC;
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarHorizontal a
display: block;
cursor: pointer;
background-color: #008C44;
padding: 0.5em 0.75em;
color: #fff;
text-decoration: none;
/* Menu items that have mouse over or focus have a blue background and white text */
ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
background-color: #E8ECF5;
color: #000000;
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
color: #000000;
SUBMENU INDICATION: styles if there is a submenu under a given menu item
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
/* background-image: url(SpryMenuBarDown.gif);
background-repeat: no-repeat;
background-position: 95% 50%; */
ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
/* background-image: url(SpryMenuBarRight.gif);
/* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a “hover” background image positioned on the far left (95%) and centered vertically (50%) */
/* background-image: url(SpryMenuBarDownHover.gif);
ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
/* background-image: url(SpryMenuBarRightHover.gif);
BROWSER HACKS: the hacks below should not be changed unless you are an expert
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarHorizontal iframe
position: absolute;
z-index: 1010;
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
ul.MenuBarHorizontal li.MenuBarItemIE
display: inline;
f\loat: left;
background: #FFF;
