  • Posted by Jamie Fritter on May 20, 2009 at 1:06 pm
    I saw the post by Samathna Brewer. My spry submenu bar is going straight across and covering the parent bar. I could not find the answer I was looking for. Please help! website is not up yet and I am stuck! This is the settings.
    @charset “UTF-8”;
    /* SpryMenuBarHorizontal.css – version 0.6 – Spry Pre-Release 1.6.1 */
    /* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
    LAYOUT INFORMATION: describes box model, positioning, z-order
    /* The outermost container of the Menu Bar, an auto width box with no margin or padding */
    ul.MenuBarHorizontal
    margin: 0;
    padding: 0;
    list-style-type: none;
    font-size: x-small;
    cursor: default;
    width: auto;
    font-family: Verdana, Geneva, sans-serif;
    font-weight: normal;
    background-repeat: repeat;
    position: relative;
    background-image:;
    /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: https://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
    ul.MenuBarActive
    z-index: 1000;
    /* Menu item containers, position children relative to this container and are a fixed width */
    ul.MenuBarHorizontal li
    margin: 0;
    padding: 0;
    font-size: 100%;
    position: relative;
    text-align: left;
    cursor: pointer;
    float: left;
    background-image: url(../Images/menu-bkg.jpg);
    width: auto;
    white-space: nowrap;
    /* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
    ul.MenuBarHorizontal ul
    margin: 0;
    padding: 0;
    font-size: 100%;
    z-index: 1020;
    cursor: default;
    width: auto;
    position: absolute;
    left: -1000em;
    top: 0;
    /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
    ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
    left: auto;
    /* Menu item containers are same fixed width as parent */
    ul.MenuBarHorizontal ul li
    width: auto;
    /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
    ul.MenuBarHorizontal ul ul
    position: absolute;
    margin: -5% 0 0 95%;
    /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
    ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
    left: 0px;
    position: relative;
    DESIGN INFORMATION: describes color scheme, borders, fonts
    /* Submenu containers have borders on all sides */
    border: 1px solid #900;
    /* Menu items are a light gray block with padding and no text decoration */
    ul.MenuBarHorizontal a
    display: block;
    cursor: pointer;
    color: #FFF;
    text-decoration: none;
    padding-top: 0.8em;
    padding-right: 1.8375em;
    padding-bottom: 0.8em;
    padding-left: 1.5em;
    /* Menu items that have mouse over or focus have a blue background and white text */
    ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
    background-color: #900;
    color: #FFF;
    border-top-color: #900;
    border-right-color: #900;
    border-bottom-color: #900;
    border-left-color: #900;
    font-size: x-small;
    /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
    ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
    color: #FFF;
    SUBMENU INDICATION: styles if there is a submenu under a given menu item
    /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
    background-image: url(SpryMenuBarDown.gif);
    background-repeat: no-repeat;
    background-position: 95% 50%;
    font-size: 100%;
    text-align: left;
    ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
    background-image: url(SpryMenuBarRight.gif);
    /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a “hover” background image positioned on the far left (95%) and centered vertically (50%) */
    background-image: url(SpryMenuBarDownHover.gif);
    ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
    background-image: url(SpryMenuBarRightHover.gif);
    BROWSER HACKS: the hacks below should not be changed unless you are an expert
    /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
    ul.MenuBarHorizontal iframe
    position: absolute;
    z-index: 1010;
    filter:alpha(opacity:0.1);
    /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
    @media screen, projection
    ul.MenuBarHorizontal li.MenuBarItemIE
    display: inline;
    float: left;
    background-image:#FFF;
    Jamie Fritter replied 17 years, 4 months ago 2 Members · 2 Replies
