Activity Forums Web Design (WordPress, Joomla, etc.) Spry Menu Bar Layered On Top of Itself in Dreamweaver
  • Spry Menu Bar Layered On Top of Itself in Dreamweaver
    Posted by Ted Cacciola on July 11, 2011 at 5:05 pm
    I inserted a spry menu bar and it looked fine. I forgot what I entered but now the menu bar is only showing my contacts menu not any of my other submenus. Also, when I go to insert a new spry menu bar. The same thing happens, only showing the last spry item. If someone could tell me what I did wrong with my code I would be very thankful.
    @charset “UTF-8”;
    /* SpryMenuBarHorizontal.css – version 0.6 – Spry Pre-Release 1.6.1 */
    /* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
    LAYOUT INFORMATION: describes box model, positioning, z-order
    /* The outermost container of the Menu Bar, an auto width box with no margin or padding */
    ul.MenuBarHorizontal
    margin: 0;
    padding: 0;
    list-style-type: lower-roman;
    font-size: 12pt;
    cursor: cell;
    width: auto;
    overflow: auto;
    visibility: inherit;
    /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: https://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
    ul.MenuBarActive
    z-index: 1000;
    left: 200px;
    /* Menu item containers, position children relative to this container and are a fixed width */
    ul.MenuBarHorizontal li
    margin: 0;
    padding: 0;
    list-style-type: none;
    font-size: 100%;
    position: absolute;
    text-align: center;
    cursor: pointer;
    width: 165px;
    float: left;
    /* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
    ul.MenuBarHorizontal ul
    margin: 0;
    padding: 0;
    font-size: 100%;
    z-index: 1020;
    cursor: default;
    width: 8.2em;
    position: absolute;
    left: -1000em;
    /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
    ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
    left: auto;
    /* Menu item containers are same fixed width as parent */
    ul.MenuBarHorizontal ul li
    width: 166.5px;
    /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
    ul.MenuBarHorizontal ul ul
    position: absolute;
    margin: -5% 0 0 95%;
    width: 166.5px;
    /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
    ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
    left: auto;
    top: 0;
    width: auto;
    DESIGN INFORMATION: describes color scheme, borders, fonts
    /* Submenu containers have borders on all sides */
    border: 1px solid #CCC;
    /* Menu items are a light gray block with padding and no text decoration */
    ul.MenuBarHorizontal a
    display: block;
    cursor: pointer;
    background-color: #FFF;
    padding: 0.5em 0.75em;
    color: #09F;
    text-decoration: none;
    font-family: vijaya;
    font-size: 16px;
    font-weight: bold;
    /* Menu items that have mouse over or focus have a blue background and white text */
    ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
    background-color: #0066CC;
    color: #FFF;
    /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
    ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
    color: #FFF;
    height: auto;
    width: 166.5px;
    SUBMENU INDICATION: styles if there is a submenu under a given menu item
    /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
    background-image: url(SpryMenuBarDown.gif);
    background-repeat: no-repeat;
    background-position: 95% 50%;
    ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
    background-image: url(SpryMenuBarRight.gif);
    position: relative;
    height: auto;
    width: 166.5px;
    /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a “hover” background image positioned on the far left (95%) and centered vertically (50%) */
    background-image: url(SpryMenuBarDownHover.gif);
    ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
    background-image: none;
    BROWSER HACKS: the hacks below should not be changed unless you are an expert
    /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
    ul.MenuBarHorizontal iframe
    position: absolute;
    z-index: 1010;
    filter:alpha(opacity:0.1);
    /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
    @media screen, projection
    ul.MenuBarHorizontal li.MenuBarItemIE
    display: inline;
    float: left;
    background: #FFF;
    Ted Cacciola replied 15 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
