Activity › Forums › Adobe After Effects › Spread Z dimension leaving relevant scale to camera intact
Posted by Francois Driessen on August 11, 2011 at 9:56 pmHi there.
Is there an easy way to spread out the z distance between layers but automatically keep their perceived scale to the camera constant?thnx.
-FFrancois
FireTrigger Inc.
https://firetrigger.comTodd Kopriva replied 15 years ago 4 Members · 4 Replies -
Kevin Camp
August 12, 2011 at 3:16 amI think this is what you are looking for:
https://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c1103906c6dea-79fca.html
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Francois Driessen
August 12, 2011 at 1:57 pmThanks, K
Was thinking there would be an expression for sure, but I need to have it set up once only, and then have the expression let go of the values so that I can generate parallax shift by animating the AE camera. Any thoughts here?
Motion had this feature to reverse scatter layers in Z space to maintain scale. (Not that Motion would work for this project) . Was wondering if AE snuck it in after the last few updates…
Francois
FireTrigger Inc.
https://firetrigger.com -
Matthew Keane
August 14, 2011 at 6:57 pmHi,
If you’re trying to spread parts of the same image out in z-space to give the illusion of depth, there’s a script called something like ‘psd2layers’ which does just that with the layers of a PSD, and applies an expression to the scale parameter so that you can slide elements around while maintaining their apparent size. Might be worth searching for, if that’s what you’re attempting.
Todd Kopriva
August 20, 2011 at 6:50 amI think that this is what you’re looking for:
https://aescripts.com/pt_multiplane/It’s linked to from After Effects Help, by the way.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
