Activity › Forums › Maxon Cinema 4D › Spout Modelling
  • Spout Modelling
    Posted by Donald Mitchell on September 23, 2006 at 1:21 pm
    I’m modelling the spout of a liquer bottle top pourer. I used two sliced toruses, one smaller diameter than the other, in a boule to create the spout. I want the edge created at the mouth to have a bevelled edge. I’m having trouble with this as the boule has created lots of extra polygons. I guess I’m asking what’s the simplest and cleanest method of bevelling the edges of holes created by a boule?
    Thanks in advance
    Mylenium replied 20 years ago 2 Members · 3 Replies
  • Mylenium
    September 24, 2006 at 12:14 pm
    Actually your entire approach is w”bad modeling technique”. You shouldn’t use booleans at all, but rather a Sweep NURBS object with a hollow profile. Not only will it give you the option to create rounded caps instantly, but even when you convert it to polygons your geometry will be much cleaner.
    Mylenium
    [Pour Myl
  • Donald Mitchell
    September 24, 2006 at 11:58 pm
    Thanks Mylenium,
    That’s a much more sensible way to model my tube. Now I have another boule question… I have a capsule primitive that I want the tube to intersect with, so that it protrudes from a hole in the capsule slightly larger than it’s diameter.
    I have made a boule with the capsule and a slightly larger version of my tube. I now have a hole in my capsule. What’s the best way of rounding or bevelling the edge of the hole so it isn’t crisp and catches the light better?
    sorry if I’m a crap modeller – even though I use c4d a reasonable amount, I just don’t get enough practice at basic modelling.
    mitchino
  • Mylenium
    September 25, 2006 at 7:59 am
    Convert your boolean to a polygon object (current state to object or simply press C), select the edges and use the bevel tool with a Convex bevel type and some more subdivisions. This will create circular fillets such as you need.
    Mylenium
    [Pour Myl
