Activity › Forums › Apple OS X › Spotlight – Spotless – Apple Fix?
  • Jeff Carpenter
    March 6, 2006 at 10:53 pm
    You can always go in the System Prefrences where the Spotlight options are and set your entire hard drive to the “do not search” setting. This is there so you can omit areas of the HD from the search but I imagine that if you set the ENTIRE hard drive to not be searched, well, you’d avoid any effects that it might otherwise inflict on you.
