Activity Forums Adobe After Effects Spotlight on grey banding
  • Spotlight on grey banding
    Posted by Joeythedog on October 20, 2005 at 2:05 am
    I have a dim soft spotlight sweep across a grey background. As the tones of grey change there is a virtual parade of banding. Is there anyway to fix this?
    As I watch television you rarely see subtle moving tones in graphics. I wonder if banding is the reason.
    Thanks for your help.
    Michael Szalapski replied 20 years, 10 months ago 3 Members · 3 Replies
  • Ben G unguren
    October 20, 2005 at 2:16 am
    Work your project in 16 bits instead of 8. Or, if that doesn’t work (it probably will, however, as long as any effects you are using are 16-bit-able), add some noise to your comp, which will break up the banding (though it usually won’t entirely fix the problem).
  • Joeythedog
    October 20, 2005 at 3:34 am
    Could one add blur along with the noise? How much noise? How much blur? Would the blur just reintroduce the banding?
  • Michael Szalapski
    October 20, 2005 at 2:50 pm
    Yes, blur would reintroduce the banding. If 16 bit didn’t help just add noise.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
