Activity › Forums › Adobe After Effects › Spotlight Effect
  • Spotlight Effect
    Posted by The_jungle on April 26, 2005 at 7:50 pm
    Hello
    I am working on a sports Documentary and I would like to create a “spotlight” effect where a small ring
    of light flows a player down the field and the rest of the video dims, I would also like to have multiple lights
    following multiple players…
    does anyone have any idea how to do this? I am fairly new to the AE world and would greatly appreciate any
    help
    Thanks a ton in advance
    Chris
    Sean Hegarty replied 17 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • X-claim
    April 26, 2005 at 9:22 pm
    You could use lights to do this, by making the footage a 3d layer and then keyframing a light to follow them.
    I would probably do it a different way though to get greater control of the image.
    I would have two layers the top one would be the light layer the bottom one the dark layer (achieve these with what ever effect you like)
    On the top layer make a circular mask and feather it however you like, then keyframe it to follow the player.
    Use multiple masks for different players if need be.
    Hope that makes sense.
    Hayden
    New Zealand
  • The_jungle
    April 26, 2005 at 10:19 pm
    Thanks for the help
    now do you know if it is possible to key frame the light using tracker data?
    and how?
    Chris
    P.S. any other suggestions?
  • Mike Clasby
    April 27, 2005 at 12:40 am
    If you have AE6.5 you might try Perspective>CC Spotlight. You can throw multiple spots on the layer, and contol the darkening, or use them as gels (Custom for each player if you like). Tracking data pasted to the “To” parameter (where the light shines on) works fine.
    I’d set up the “From parameter for each light. The light changes shape as they move depending on the From-To controls, after a few minuted fooling around you’ll get a feel for it.
  • The_jungle
    April 27, 2005 at 6:23 pm
    Thanks for you suggestion
    However I cant seem to find the effect you are refering to
    I do have AE 6.5 and I am looking in
    Effects>Perspective
    But the only effects I see in there are Bevels and drop shadows
    am I looking in the wrong place?
  • Steve Roberts
    April 27, 2005 at 6:36 pm
    Did you install the Cycore effects from the AE CD?
    Steve
  • The_jungle
    April 27, 2005 at 6:39 pm
    Sorry My Bad, I did not see them on the CD when I did my initial install
    Chris
  • Sean Hegarty
    August 27, 2009 at 7:50 pm
    How would you do this with AE 7.0?
